Dataflow Round Object Property Value
The Round Object Property Value dataflow rounds a selected numeric property value according to the number of decimals defined in the dataflow settings. The rounding can be applied to all objects or only to selected ones, depending on the chosen target. Note that the original value will be overwritten and cannot be restored.
This dataflow allows you to round numeric values to the level of precision that best fits your use case.
Target Objects
The objects to which the rounded value will be set. The default value for the target is All.
Property Set
Defines the name of the property set that contains the selected property to be rounded.
Property
The name of the existing property you want to round.
Nr of Decimals
The number of decimals to use for rounding the value. The original value will be overwritten by the rounded value.
