Bimsheet: Enrich
The Bimsheet: Enrich tool imports data from a special Excel file called Bimsheet. You can define Bimsheet files in Bimsheet palette.
Use this tool for adding information from Excel into your model. The workflow inside this tool is the following:
  1. Opens a Bimsheet Enrichment file (Excel)
  2. Writes the information from the Bimsheet enrichment file into your model
Bimsheet Enrichment File Name
Defines the full path and name, including file extension, for the Bimsheet Enrichment Excel file containing the data used for enriching the model.
Type in the path and name, or click on the three dots to select the file with the File Selector dialog.
