The Duplicate Object Property dataflow duplicates the values of a selected property into a new user-defined text property within a user-defined property set. This property can be added to all objects or only to selected object classes, depending on the chosen target. This dataflow also allows you to exclude the original property used to create the new property.
The idea is to make it possible to add properties to objects, enabling them to store the values needed for organizing and using the IFC model.
Target Objects
The object class or classes the new property will be added to. The default value for the target is All.
Original Property:
Property
The existing property whose value will be copied into the new property.
Exclude the Original Property
This option allows you to exclude the original property. Depending on the chosen target, the properties will be excluded either from all objects or only from selected object classes.
Duplicate Property:
Property Set
Defines the property set name for the new property. You can use an existing property set or create a new one. Note that the property set name cannot be Simplebim.
New Property
The name of the new property.
