Add Geometry Tags
The Add Geometry Tags tool adds a new Geometry Tag property (text) to all objects that have a 3D geometry. If two objects have an identical geometry, they will get the same tag. This is also true when the geometries are rotated differently. As a result, the Geometry Tag property will have a unique value for each unique geometry in the model.
Target
Defines the objects to which the geometry tag is added.
