| Issue | You may get an error message in the 3D palette that reads (or similar):DirectX device reset failed with error code:D3DERR_DEVICELOSTThis may happen for example when you put Windows into sleep mode and Simplebim is running. (or similar) |
| Solution | The solution is to reload the 3D palette. Simply click ‘Reload 3D’ in the ‘3D’ ribbon tab |
